本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show the steps needed to remove the EPP (Expanded Polypropylene) or Styrofoam Nose. The Styrofoam nose protects the motherboard and the GPS Module. In order to remove the Nose, the battery will have to be removed first.
你所需要的
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
即将完成!
To reassemble your device, follow these intructions in reverse order
结论
2等其他人完成本指南。
