跳转到主内容
Parrot Bebop Drone Styrofoam Nose Replacement
你所需要的
  1. Parrot Bebop Drone Styrofoam Nose Replacement, Battery: 步骤 1 中的图像 1,2 Parrot Bebop Drone Styrofoam Nose Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 2 中的图像 1,2 Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 2 中的图像 2,2
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 3 中的图像 1,3 Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 3 中的图像 2,3 Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 3 中的图像 3,3
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: 步骤 4 中的图像 1,2 Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: 步骤 4 中的图像 2,2
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 5 中的图像 1,1
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone Styrofoam Nose Replacement: 步骤 6 中的图像 1,1
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
结论
To reassemble your device, follow these intructions in reverse order
2等其他人完成本指南。
团队
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 的会员
UWT-ROSE-W17S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 924
