跳转到主内容
Parrot Bebop Drone Propeller Replacement
  1. Parrot Bebop Drone Propeller Replacement, Propeller: 步骤 1 中的图像 1,3 Parrot Bebop Drone Propeller Replacement, Propeller: 步骤 1 中的图像 2,3 Parrot Bebop Drone Propeller Replacement, Propeller: 步骤 1 中的图像 3,3
    • Using the propeller removal tool (included with the Parrot Bebop Drone), line up the holes with the protruding screws.
  2. Parrot Bebop Drone Propeller Replacement: 步骤 2 中的图像 1,2 Parrot Bebop Drone Propeller Replacement: 步骤 2 中的图像 2,2
    • While holding the propeller in place, rotate the tool counterclockwise until the screws are aligned with the holes on the propeller.
  3. Parrot Bebop Drone Propeller Replacement: 步骤 3 中的图像 1,1
    • While gently pushing down on the arm of which the propeller is attached, pull the propeller up off the motor.
  4. Parrot Bebop Drone Propeller Replacement: 步骤 4 中的图像 1,3 Parrot Bebop Drone Propeller Replacement: 步骤 4 中的图像 2,3 Parrot Bebop Drone Propeller Replacement: 步骤 4 中的图像 3,3
    • When putting the propellers back on, the red propellers go up front and the black ones go on the back.
    • The motors with the protruding axles (front right and rear left) have the propeller with the hole in the middle while the motors without the protruding axles (front left and rear right) have the propellers without the hole in the middle.
结论
3等其他人完成本指南。
Nazar Savchuk
于01/25/17注册
303 声望
创作了2篇指南
团队
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 的会员
UWT-ROSE-W17S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 2,192
