简介
Use this guide to replace a broken propeller on your Parrot Bebop.
You will need the Bebop propeller removal tool. Be sure to place the propellors on the proper engines. Propellers with central holes fit over the engines with a central screw. Flat propellers fit on flat engines. Propellers with central screws should be diagonally opposite each other, and propellers without holes should be diagonally opposite each other.
你所需要的
视频介绍
3等其他人完成本指南。
2条评论
Dear Sir I do not have any money buy an expensive drone so I bought a Ttr003 hornet, and on the first flight it caught in a tree and stripped the small drive gear, I have tried to get in touch with the manufacturer, with no success and spares seem to be nonexistent, the shaft is only 1mm Itried to find a metal drive with 12teeth and a 1mm shaft. I would be happy if you could suggest something , possibly throwing it out the window or a solution.
Yours MAX
email maxm643@gmail.com
max - 回复
Trying to find a supplier for propellers for the bebop 1. Any ideas appreciated.
Any location considered as I'm in Ireland. So happy to deal with AliExpress etc but can't find any propellers.
shamrock island - 回复
