跳转到主内容
Parrot Bebop Drone GPS Board Replacement
你所需要的
  1. Parrot Bebop Drone GPS Board Replacement, Battery: 步骤 1 中的图像 1,2 Parrot Bebop Drone GPS Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone GPS Board Replacement: 步骤 2 中的图像 1,2 Parrot Bebop Drone GPS Board Replacement: 步骤 2 中的图像 2,2
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone GPS Board Replacement: 步骤 3 中的图像 1,3 Parrot Bebop Drone GPS Board Replacement: 步骤 3 中的图像 2,3 Parrot Bebop Drone GPS Board Replacement: 步骤 3 中的图像 3,3
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: 步骤 4 中的图像 1,2 Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: 步骤 4 中的图像 2,2
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone GPS Board Replacement: 步骤 5 中的图像 1,1
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone GPS Board Replacement: 步骤 6 中的图像 1,1
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Parrot Bebop Drone GPS Board Replacement, GPS Board: 步骤 7 中的图像 1,1
    • Remove the cable from the top of the GPS module.
  8. Parrot Bebop Drone GPS Board Replacement: 步骤 8 中的图像 1,2 Parrot Bebop Drone GPS Board Replacement: 步骤 8 中的图像 2,2
    • Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
    • Remove the 4mm T5 Screw holding the GPS Module.
  9. Parrot Bebop Drone GPS Board Replacement: 步骤 9 中的图像 1,1
    • Remove the GPS board by lifting it off of the metal frame.
结论
4等其他人完成本指南。
Austin
于02/02/17注册
185 声望
撰写一个指南
团队
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 的会员
UWT-ROSE-W17S1G3
4 名成员
创作了5篇指南
一条评论
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
Albert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,695
