简介
How to replace a damaged motor. Before beginning, check the position of the 4 different propellers, type "A" or "C".
Step 1 : Remove the propeller, shaft & gear
Step 2 : Remove the damaged motor screws
Step 3 : Remove the damaged motor
Step 4 : Mount the new motor
Step 5 : Fix the new motor screws
Final step : Fix the propeller, shaft & gear
你所需要的
视频介绍
即将完成!
结论
一条评论
Is the Parrot AR.Drone1.0 Motor compatible with Parrot AR.Drone2.0 motor ? thanks
herrydianto - 回复
