跳转到主内容
Parrot AR.Drone 2.0 Central Cross Replacement
你所需要的
视频概述
  1. Parrot AR.Drone 2.0 Central Cross Replacement, Mainboard and Navigation Board: 步骤 1 中的图像 1,1
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 2 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 2 中的图像 2,2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 3 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 3 中的图像 2,2
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  4. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 4 中的图像 1,3 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 4 中的图像 2,3 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 4 中的图像 3,3
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  5. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 5 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
    How can I get that connector, the one it’s disconnected?
    gui txr - 回复
  6. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 6 中的图像 1,1
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  7. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 7 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the secondary board from the mainboard.
  8. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 8 中的图像 1,3 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 8 中的图像 2,3 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 8 中的图像 3,3
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  9. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 9 中的图像 1,1
    • Release the rubber clip holding the USB and battery power cable to the body.
  10. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 10 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 10 中的图像 2,2
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  11. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 11 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 11 中的图像 2,2
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  12. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 12 中的图像 1,2 Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 12 中的图像 2,2
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  13. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 13 中的图像 1,1
    • The mainboard is now fully detached and can be removed.
  14. Parrot AR.Drone 2.0 Central Cross Replacement, Central Cross: 步骤 14 中的图像 1,1
    • Using a nylon spudger, peel off the four pieces of plastic securing the frame to the body.
  15. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 15 中的图像 1,1
    • Carefully maneuver the four arms of the drone’s central cross until it detaches from the body by pulling apart the foam surrounding the arms.
    between arm 1 and arm 2 there is a little triangle on the central cross, that should point to the front.
    deebee122 - 回复
  16. Parrot AR.Drone 2.0 Central Cross Replacement: 步骤 16 中的图像 1,1
    • The central cross can now be removed and replaced.
    deebee122 - 回复
结论
4等其他人完成本指南。
David Hoyt
于04/09/10注册
4,023 声望
创作了43篇指南
团队
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G89
4 名成员
创作了63篇指南
2条评论
If the crossbones are off just a bit would that effect the flight?
John Wurst - 回复
So once I have removed the central cross, how do I put it all back together again?? I feel as though this is letting your guide down!!!!
Jacob Kenworthy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 6,137
