跳转到主内容
Pantech Matrix Speaker Replacement
你所需要的
  1. Pantech Matrix Speaker Replacement, Phone Orientation: 步骤 1 中的图像 1,1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Speaker Replacement, Phone Orientation: 步骤 2 中的图像 1,1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Speaker Replacement, Remove Back Cover: 步骤 3 中的图像 1,2 Pantech Matrix Speaker Replacement, Remove Back Cover: 步骤 3 中的图像 2,2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Speaker Replacement, Lift Battery: 步骤 4 中的图像 1,1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Speaker Replacement, Remove Battery: 步骤 5 中的图像 1,1
    • Remove the battery from its dock.
  6. Pantech Matrix Speaker Replacement, Slide SIM Card Out: 步骤 6 中的图像 1,3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: 步骤 6 中的图像 2,3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: 步骤 6 中的图像 3,3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Speaker Replacement, Remove Phone Screws: 步骤 7 中的图像 1,2 Pantech Matrix Speaker Replacement, Remove Phone Screws: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Speaker Replacement, Remove Phone Casing: 步骤 8 中的图像 1,3 Pantech Matrix Speaker Replacement, Remove Phone Casing: 步骤 8 中的图像 2,3 Pantech Matrix Speaker Replacement, Remove Phone Casing: 步骤 8 中的图像 3,3
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside the rest of the phone.
  9. Pantech Matrix Speaker Replacement, Remove Phone Speaker: 步骤 9 中的图像 1,2 Pantech Matrix Speaker Replacement, Remove Phone Speaker: 步骤 9 中的图像 2,2
    • Place the spudger in the notch on the side of the speaker as shown.
    • Use the spudger to gently pry the speaker loose from its dock.
    • Remove the speaker fully from the phone.
结论
Zeel Patel
于10/13/14注册
1,096 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 272
