当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Near the hinge of the phone there is a green circuit board.
On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
The LCD screen is the metal square with the black LCD screen in the middle. This should not be confused with the clear plastic protective screen on the front of the phone. The LCD screen is displayed here with a blue arrow.
Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic piece with the spudger.
这个步骤还没有翻译 帮忙翻译一下
Note: If your replacement LCD screen came with microphone, speakers, etc. attached by wires already, simply remove the existing LCD, microphone, etc. (since they are already attached) and you will not need to perform any of the cutting or soldering steps. You can simply insert the new screen and accessories, and close up the phone.
Note: If your replacement LCD screen did not come with microphone, speakers, etc. attached, then continue the guide as written.
Using scissors, disconnect the speaker from the phone.
Note: all steps involving scissors and soldering are not displayed in this guide or have already been performed in the pictures. Your phone will look different from these pictures, since the cutting steps have not been performed. Follow the steps in the guide for true instructions - pictures are only to help illustrate locations of steps.
这个步骤还没有翻译 帮忙翻译一下
Pull the wires from the screen which connect to the speaker carefully.
这个步骤还没有翻译 帮忙翻译一下
Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
这个步骤还没有翻译 帮忙翻译一下
Make sure all of the wires are out of the way before inserting new screen.
这个步骤还没有翻译 帮忙翻译一下
Put the new screen into the phone.
这个步骤还没有翻译 帮忙翻译一下
Solder wires into screen if necessary.
