跳转到主内容
Pantech CDM8975 Keyboard Replacement
你所需要的
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: 步骤 3 中的图像 1,1
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
结论
You now have a new keyboard.
2等其他人完成本指南。
Richard
于02/13/14注册
116 声望
撰写一个指南
团队
Ohio State, Team 1-4, Meza Spring 2014 Ohio State, Team 1-4, Meza Spring 2014 的会员
OSU-MEZA-S14S1G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 359
