跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide should help the reader through the necessary steps to successfully replace the Motherboard of your Pantech Burst. Be aware that the insides of the phone can be easily damaged and must be handled carefully.
  1. Power off your phone before beginning disassembly. Turn over the phone so that you're facing the back cover. Locate the indent(?) below the back cover.
    • Power off your phone before beginning disassembly.
    • Turn over the phone so that you're facing the back cover.
    • Locate the indent(?) below the back cover.
    • Using a fingernail, pull up to remove the back cover.
    • Removing the back cover may require some force.
  2. Locate the silver battery. It is the big, rectangular, silver tape on black plastic object. Find the gap between the battery and the rest of the device. Using your fingernail, gently pull the battery up and away from the rest of the device.
    • Locate the silver battery. It is the big, rectangular, silver tape on black plastic object.
    • Find the gap between the battery and the rest of the device.
    • Using your fingernail, gently pull the battery up and away from the rest of the device.
  3. Undo all 8 visible screws using a phillips size 000 screwdriver. The screws are marked in red on the picture. The screws are marked in red on the picture.
    • Undo all 8 visible screws using a phillips size 000 screwdriver.
    • The screws are marked in red on the picture.
  4. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Remove the SD card if there is one inserted into the phone. Remove the SD card if there is one inserted into the phone.
    • Remove the SD card if there is one inserted into the phone.
  6. Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port. Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged. Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
    • Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
    • Once there is space enough to pull the pieces apart with your fingers, you may do so.
    • Opening the phone may require a good amount of force.
  7. Unscrew the screw with a phillips size 000 screwdriver. Disconnect the blue connector from the motherboard using a fingernail to lightly pull up. Gently remove the SIM/SD card part.
    • Unscrew the screw with a phillips size 000 screwdriver.
    • Disconnect the blue connector from the motherboard using a fingernail to lightly pull up.
    • Gently remove the SIM/SD card part.
  8. Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Gently disconnect the connectors attached to the motherboard using a fingernail to pull them up from the board.
    • Connectors are marked in blue in the image.
  9. Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device. Beginning with the side with the USB port may damage the phone. Beginning with the side with the USB port may damage the phone.
    • Starting from the bottom and going around counterclockwise, carefully pry the motherboard out of the device.
    • Beginning with the side with the USB port may damage the phone.
结论
Kyle Kurashima
于2015年09月29日注册
111 信誉积分
撰写一个指南
团队
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015 的会员
CPSU-GREEN-F15S15G1
5 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 286
