简介
This guide should help the reader through the necessary steps to successfully replace the Motherboard of your Pantech Burst. Be aware that the insides of the phone can be easily damaged and must be handled carefully.
你所需要的
Turn over the phone so that you're facing the back cover.
Locate the indent(?) below the back cover.
Using a fingernail, pull up to remove the back cover.
Using an opening tool or some other solid, flat-ended tool, begin pulling apart the phone from the indent below the USB port.
Continue using the tool, while moving around the edge of the phone until the two parts are largely disengaged.
Once there is space enough to pull the pieces apart with your fingers, you may do so.
