跳转到主内容
Pantech Breakout Rear Facing Camera Replacement
你所需要的
  1. Pantech Breakout Rear Facing Camera Replacement, Removing Back Cover: 步骤 1 中的图像 1,3 Pantech Breakout Rear Facing Camera Replacement, Removing Back Cover: 步骤 1 中的图像 2,3 Pantech Breakout Rear Facing Camera Replacement, Removing Back Cover: 步骤 1 中的图像 3,3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Rear Facing Camera Replacement, Removing the Battery: 步骤 2 中的图像 1,2 Pantech Breakout Rear Facing Camera Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
  3. Pantech Breakout Rear Facing Camera Replacement, Remove Screws: 步骤 3 中的图像 1,1
    • With the phone face down on a hard surface, locate the six 3.5mm Phillips screws around the perimeter of the phone.
    • Three of these screws are black, while three are silver.
    • Use a Phillips #00 or #000 screwdriver to remove all six Phillips screws.
    • Righty Tighty, Lefty Loosey!
  4. Pantech Breakout Rear Facing Camera Replacement, Separating the Back Case: 步骤 4 中的图像 1,2 Pantech Breakout Rear Facing Camera Replacement, Separating the Back Case: 步骤 4 中的图像 2,2
    • Be careful when prying the plastic bezel and back case apart from each other; the parts are connected by both snaps and adhesive. Forcing the back case off could result in it breaking or cracking.
    • Slide a Plastic Opening Tool in between the front bezel and the back case, slowly working it around the tight edges.
    • Be patient, it may take several tries to remove the bezel and back case successfully. You may need to slide repeatedly along the edges of the entire phone perimeter to loosen the adhesive between the two pieces.
  5. Pantech Breakout Rear Facing Camera Replacement, Removing Back Case: 步骤 5 中的图像 1,2 Pantech Breakout Rear Facing Camera Replacement, Removing Back Case: 步骤 5 中的图像 2,2
    • Starting at the charging port cover open by prying away from front face to remove back case.
    • Make sure that no part of the back case is caught on any other part of the phone; the USB charging port can get in the way.
    • After removing the bevel and back case of the phone, you will now see the motherboard and other internal components.
  6. Pantech Breakout Rear Facing Camera Replacement, Component Board Separation: 步骤 6 中的图像 1,3 Pantech Breakout Rear Facing Camera Replacement, Component Board Separation: 步骤 6 中的图像 2,3 Pantech Breakout Rear Facing Camera Replacement, Component Board Separation: 步骤 6 中的图像 3,3
    • After removal of front bezel and back cover, locate and remove two Phillips #000 screws from the top corners of the phone.
    • After taking out the screws, lift off the black plastic piece containing the speaker, Micro SD card slot and SIM card slot.
  7. Pantech Breakout Rear Facing Camera Replacement, Disconnecting Ribbon Cables: 步骤 7 中的图像 1,3 Pantech Breakout Rear Facing Camera Replacement, Disconnecting Ribbon Cables: 步骤 7 中的图像 2,3 Pantech Breakout Rear Facing Camera Replacement, Disconnecting Ribbon Cables: 步骤 7 中的图像 3,3
    • Locate the four ribbon connections near the top of the phone, above where the battery was.
    • Using a set of Tweezers, carefully pull each ribbon up from its connection. After this is complete, the motherboard will freely separate from the back of the screen.
    • Separate motherboard from screen.
    • The vibrator motor will be dangling from the motherboard by a wire, it is not detachable.
  8. Pantech Breakout Rear Facing Camera Replacement, Removing Rear Facing Camera: 步骤 8 中的图像 1,2 Pantech Breakout Rear Facing Camera Replacement, Removing Rear Facing Camera: 步骤 8 中的图像 2,2
    • The rear facing camera is attached to the back of the screen with adhesive.
    • To remove, apply constant pressure with a prying tool at the base of the camera.
结论
When re-installing a rear facing camera, it might be necessary to add a small amount of adhesive to the base of the camera to keep it in place. Also, the cable ribbon of the rear facing camera should lead out of the bottom of the camera.
Ryan Murphy
于09/25/14注册
898 声望
创作了7篇指南
团队
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 140
