跳转到主内容
Pantech Breakout Battery Replacement
你所需要的
  1. Pantech Breakout Battery Replacement, Removing Back Cover: 步骤 1 中的图像 1,3 Pantech Breakout Battery Replacement, Removing Back Cover: 步骤 1 中的图像 2,3 Pantech Breakout Battery Replacement, Removing Back Cover: 步骤 1 中的图像 3,3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Battery Replacement, Removing the Battery: 步骤 2 中的图像 1,2 Pantech Breakout Battery Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
结论
另外一个人完成了本指南。
Ryan Murphy
于09/25/14注册
898 声望
创作了7篇指南
团队
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,909
