跳转到主内容
Pandigital Novel PRD07T10WWH7 Battery Replacement
你所需要的
  1. Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Pandigital Novel PRD07T10WWH7 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 2 中的图像 1,2 Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 2 中的图像 2,2
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the 12 4mm screws on the outer area of the gray area exposed by removing the back panels.
  4. Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 4 中的图像 1,2 Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully pry the back of the device from the front panel and motherboard. There are a series of clips holding them together that need to be separated.
  5. Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 5 中的图像 1,2 Pandigital Novel PRD07T10WWH7 Battery Replacement: 步骤 5 中的图像 2,2
    • Now, lift up the gray piece, unplug the battery connector, and the battery can be removed from the case.
结论
另外一个人完成了本指南。
Carl Weber
于10/21/16注册
328 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 UMass Dartmouth, Team 3-7, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,254
