跳转到主内容
Panasonic Viera - HDMI Input Board Replacement
你所需要的
  1. Panasonic Viera - HDMI Input Board  Replacement, Remove TV From Stand: 步骤 1 中的图像 1,1
    • Remove the TV from the stand and place glass down on a flat, soft, and clean surface where you will have easy access to all four sides of it.
  2. Panasonic Viera - HDMI Input Board  Replacement, Check/Confirm Model Number: 步骤 2 中的图像 1,1
    • The model number of your TV is located on the back panel.
    • This guide was written specifically for a TC-P55VT50 (55 Inch Panasonic Viera Plasma TV) model year 2012.
    • Other Panasonic Viera's may be similar - but I make no promises!
  3. Panasonic Viera - HDMI Input Board  Replacement, Prepare TV for Surgery: 步骤 3 中的图像 1,1
    • Remove the power cord and place the TV screen down on a soft surface, like a blanket.
    • The back of the TV is held in place by many small Phillips head screws. Most of these are around the edges but there are also some by the power input and media inputs. Make sure to keep these screws in a safe place!
    • Per Dave Watson's comment, as you remove all of the screws in the back that at the bottom of the TV, there are two components that you have to unscrew and remove: the WIFI and blue tooth modules. The blue tooth module has a clip at the top that must be pushed down so you can remove it. The WIFI pops right off.
  4. Panasonic Viera - HDMI Input Board  Replacement, View of the TV with back cover removed: 步骤 5 中的图像 1,1
    • With the back cover removed we can see that everything is spread out. Be careful of the copper coils in the middle as these are part of the TV's power supply.
    • The board we want to replace is located in the lower right - see red box in image.
  5. Panasonic Viera - HDMI Input Board  Replacement, Disconnect cables and ribbons from board: 步骤 6 中的图像 1,1
    • To remove the board, we first need to remove all the various connectors to it. Note that ribbon cables are a little tricky with the connector folding down onto the ribbon.
  6. Panasonic Viera - HDMI Input Board  Replacement, Remove first mounting bracket: 步骤 7 中的图像 1,1
    • Remove the first mounting bracket - note that it overlays the bottom bracket, the order that these are removed is important.
  7. Panasonic Viera - HDMI Input Board  Replacement, Remove second/lower mounting bracket: 步骤 8 中的图像 1,1
    • Remove the second mounting bracket on the lower side of the TV.
  8. Panasonic Viera - HDMI Input Board  Replacement, Remove the board!: 步骤 9 中的图像 1,1
    • Note that there is a small amount of soft silicone under the board so you may have to wiggle it lose.
    • Now that you have liberated the HDMI input board you can send it away for repairs.
    • While you have the cover off your TV - consider cleaning the two fans as mine were dusty and starting to make some noise.
结论
10等其他人完成本指南。
Daniel Moore
于12/03/16注册
431 声望
撰写一个指南
16条评论
How did you know that board was the faulty part? Thanks
buyingclimax - 回复
The built in apps still worked, as did the component input. Only the HDMI inputs did not work. Plus, some googling revealed it is sensitive to power surges and we had a storm before it stopped working.
Daniel Moore -
Out of curiosity, where did you mail it for repair?
Nathan White - 回复
PTS Electronics, Inc.
http://www.ptselectronicsinc.com/
No issues, mailed the board in, waited, got it back and it worked. Never had to email or call anyone. It was $95 at the time.
Daniel Moore -
These instructions make me feel confident that I can do it. Great job thanks
John Romano - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 94
总计 33,405
