跳转到主内容
Panasonic Toughbook CF-53 Optical Drive Replacement
你所需要的
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,2 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 2,2
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,614
