跳转到主内容
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Panasonic Toughbook CF-53 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Panasonic Toughbook CF-53 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-53 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: 步骤 3 中的图像 1,3 Panasonic Toughbook CF-53 Battery Replacement: 步骤 3 中的图像 2,3 Panasonic Toughbook CF-53 Battery Replacement: 步骤 3 中的图像 3,3
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
结论
4等其他人完成本指南。
一条评论
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 25
过去 30 天: 119
总计 6,697
