跳转到主内容
Panasonic Toughbook CF-29 Speaker Replacement
你所需要的
  1. Panasonic Toughbook CF-29 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 Speaker Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Speaker Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 6 中的图像 1,2 Panasonic Toughbook CF-29 Speaker Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 7 中的图像 1,1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 8 中的图像 1,1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Speaker Replacement, Speaker: 步骤 9 中的图像 1,1
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
  10. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 10 中的图像 1,1
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
  11. Panasonic Toughbook CF-29 Speaker Replacement: 步骤 11 中的图像 1,1
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
结论
Rohun Heesen
于04/13/10注册
420 声望
创作了2篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 5,262
