跳转到主内容
Panasonic Toughbook CF-29 RAM Replacement
你所需要的
  1. Panasonic Toughbook CF-29 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 RAM Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 RAM Replacement: 步骤 4 中的图像 1,1
    • Pull the clips aside to release and remove the RAM.
结论
2等其他人完成本指南。
Devon Augustus
于04/12/10注册
130 声望
创作了2篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
2条评论
Thanks for sharing this. I just bought a panasonic toughbook from http://buytough.com and I think this will come in handy. :)
Katie Sutton - 回复
there is another ram slot you failed to mention
sparkynaz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 18,306
