跳转到主内容
Panasonic Toughbook CF-29 Optical Drive Replacement
  1. Panasonic Toughbook CF-29 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Optical Drive Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Optical Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Optical Drive Replacement: 步骤 5 中的图像 1,2 Panasonic Toughbook CF-29 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Push the exposed switch to the left to eject the optical drive.
结论
2等其他人完成本指南。
Clint Kirsop
于04/13/10注册
109 声望
创作了4篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
一条评论
What kind of USB enclosure would this fit in?
Terence Higgins - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,794
