简介
This guide will tell you how to gain access to and remove the motherboard.
你所需要的
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the black and white wires attached to the wireless card by simply pulling up.
Remove 2 long screws indicated with red circles
Remove the remaining screws indicated in blue
I had two more screws to remove in addition to those shown with the blue circles. One in the lower right corner so that you can remove the 14-pin connector that has a metal guard barely wrapped around the edge of the motherboard, the other is on a rectangular copper pad (and has a black arrow by the screwhead) above one of the blue circles near the lower left corner of the large module below the expansion connector.
Lift the motherboard as shown, pull towards you and then up.
Between the power connector and the back USB port, there's a post through the motherboard just below the #1 Philips screw you removed previously. The motherboard needs to be lifted off that post to get it out.
Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
I also had a 2-pin black connector/cable going to the daughterboard that needed to be removed.
8等其他人完成本指南。
4条评论
what about spare parts? is it possible cange MOBO and CPU? in order to upgrade the thoughbook?
Où acheter la carte mère?
MERCI
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
