跳转到主内容
Panasonic Toughbook CF-29 Motherboard Replacement
你所需要的
  1. Panasonic Toughbook CF-29 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Motherboard Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Locate the door for the hard drive on the right side of the laptop
  4. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 4 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
  5. Panasonic Toughbook CF-29 Motherboard Replacement, Optical Drive: 步骤 5 中的图像 1,1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  6. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Slide the latch cover to the right.
  7. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 7 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Push the exposed switch to the left to eject the optical drive.
  8. Panasonic Toughbook CF-29 Motherboard Replacement, Back Cover: 步骤 8 中的图像 1,1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  9. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  10. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  11. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 11 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  12. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  13. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Now the back cover should be off and you can access the inside of the casing.
  14. Panasonic Toughbook CF-29 Motherboard Replacement, Wireless Card: 步骤 14 中的图像 1,1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  15. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Peel back the black cover to expose the clips holding in the wireless card.
  16. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  17. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 17 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 17 中的图像 2,2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
  18. Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 步骤 18 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement, Motherboard: 步骤 18 中的图像 2,2
    • Unplug 3 cables
    • Lift up on brown tab to release cable
    • Pull cable up and out
  19. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 19 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Remove 2 long screws indicated with red circles
    • Remove the remaining screws indicated in blue
    I had two more screws to remove in addition to those shown with the blue circles. One in the lower right corner so that you can remove the 14-pin connector that has a metal guard barely wrapped around the edge of the motherboard, the other is on a rectangular copper pad (and has a black arrow by the screwhead) above one of the blue circles near the lower left corner of the large module below the expansion connector.
    Richard Ekblaw - 回复
  20. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 20 中的图像 1,1
    • On the back of the unit, unscrew the three screws surrounding the serial port.
  21. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Lift the motherboard as shown, pull towards you and then up.
    • Do not yet try to fully remove the motherboard or you may destroy the connections
    Between the power connector and the back USB port, there's a post through the motherboard just below the #1 Philips screw you removed previously. The motherboard needs to be lifted off that post to get it out.
    Richard Ekblaw - 回复
  22. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 22 中的图像 1,1
    • Detach the white ribbon cable, the white cluster connector, and the ribbon cable right next to the cluster
    I also had a 2-pin black connector/cable going to the daughterboard that needed to be removed.
    Richard Ekblaw - 回复
  23. Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 23 中的图像 1,2 Panasonic Toughbook CF-29 Motherboard Replacement: 步骤 23 中的图像 2,2
    • Remove the board.
结论
8等其他人完成本指南。
Dylan Bloom
于04/12/10注册
373 声望
创作了4篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
4条评论
what about spare parts? is it possible cange MOBO and CPU?  in order to upgrade the thoughbook?
Concetto Salierno - 回复
I think y'all missed a step.
Gemini - 回复
Où acheter la carte mère?
MERCI
Pascal Cohu - 回复
Sur Google, recherchez "DL3UP1396AAA Panasonic CF-29 System Board" (à rechercher sans les guillemets), vous aurez quelques résultats (j'ai vu au moins 2 sites qui la propose à la vente), par contre, elle est cher.
Autre recherche possible : "DL3UP1396BAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Autre recherche possible : "DL3U11213FAA Panasonic CF-29 System Board", je ne connais pas la différence entre ces variantes
Brendan -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 28
总计 25,810
