跳转到主内容
Panasonic Toughbook CF-29 Keyboard Replacement
你所需要的
  1. Panasonic Toughbook CF-29 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the four screws above the keyboard using a Phillips #0 screwdriver.
  4. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Pry up the black panel covering the top of the keyboard.
  5. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the five silver screws shown.
  6. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Pull up keyboard and place it face down on the trackpad
    • Be careful not to put tension in the ribbon cables attached to the underside of the keyboard
  7. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove screws shown from cover plate
  8. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 8 中的图像 1,2 Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Pull cover plate out of place revealing the ribbon cable connections to the motherboard
  9. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 9 中的图像 1,2 Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove the ribbon cable farthest from you.
    • Push the white tab (as shown in the second photo) to release the ribbon cable.
  10. Panasonic Toughbook CF-29 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
结论
3等其他人完成本指南。
Dylan Bloom
于04/12/10注册
373 声望
创作了4篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
一条评论
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
Black Hawk - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 17,170
