当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the bay door for the battery on the left side of the laptop.
Slide the latch to the right and then down to unlock it.
Pull out the battery.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Be careful when lifting the cover as you may damage some connections.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Now the back cover should be off and you can access the inside of the casing.
Locate the heat sink on the underside of the back cover.
It is the U shaped metallic piece.
Remove the four screws with a Phillips size 1 screwdriver.
One on each of the ends
Two on the base of the U shape
Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与7其他贡献者
于04/13/10注册
109 声望
创作了4篇指南
徽章: 12
+ 9更多徽章
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 13
总计 5,808
