当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the bay door for the battery on the left side of the laptop.
Slide the latch to the right and then down to unlock it.
Pull out the battery.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Slide the latch cover to the right.
Push the exposed switch to the left to eject the optical drive.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Be careful when lifting the cover as you may damage some connections.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Now the back cover should be off and you can access the inside of the casing.
取消:我没有完成这个指南。
3等其他人完成本指南。
与7其他贡献者
于04/13/10注册
426 声望
创作了2篇指南
徽章: 17
+ 14更多徽章
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
thanks for this crucial tuatorial >
Joe Gutierrez - 2021年3月14日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 10,065
