跳转到主内容
Panasonic Toughbook CF-29 Back Cover Replacement
你所需要的
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 2 中的图像 1,2 Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: 步骤 3 中的图像 1,1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 4 中的图像 1,1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 5 中的图像 1,2 Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 5 中的图像 2,2
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: 步骤 6 中的图像 1,1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 7 中的图像 1,1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 9 中的图像 1,2 Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 9 中的图像 2,2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 10 中的图像 1,1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: 步骤 11 中的图像 1,1
    • Now the back cover should be off and you can access the inside of the casing.
结论
3等其他人完成本指南。
Rohun Heesen
于04/13/10注册
426 声望
创作了2篇指南
团队
Cal Poly, Team 27-93, Amido Spring 2010 Cal Poly, Team 27-93, Amido Spring 2010 的会员
CPSU-AMIDO-S10S27G93
4 名成员
创作了26篇指南
一条评论
thanks for this crucial tuatorial >
Joe Gutierrez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 10,050
