跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Panasonic Super Lite Flashlight,请使用我们的维修手册
  1. Panasonic Super Lite Flashlight Teardown, Panasonic Super Lite Flashlight Teardown: 步骤 1 中的图像 1,1
    • Twist the top assembly of the flashlight off by turning it counterclockwise above the rubber gasket.
  2. Panasonic Super Lite Flashlight Teardown: 步骤 2 中的图像 1,1
    • Orient the top assembly with the lens downward to avoid dropping the bulb during this step.
    • Unscrew the bulb base by twisting counter-clockwise, taking care not to drop the bulb. Remove the bulb.
  3. Panasonic Super Lite Flashlight Teardown: 步骤 3 中的图像 1,1
    • Remove the rubber gasket from the top assembly.
  4. Panasonic Super Lite Flashlight Teardown: 步骤 4 中的图像 1,3 Panasonic Super Lite Flashlight Teardown: 步骤 4 中的图像 2,3 Panasonic Super Lite Flashlight Teardown: 步骤 4 中的图像 3,3
    • Remove the reflector by applying pressure to one of the two protruding plastic tabs using a small flathead screwdriver while pulling on the reflector.
    • The reflector should pop out; pull gently but firmly to avoid scattering the pieces. Remove the lens.
  5. Panasonic Super Lite Flashlight Teardown: 步骤 5 中的图像 1,1
    • Remove the batteries from the flashlight body.
  6. Panasonic Super Lite Flashlight Teardown: 步骤 6 中的图像 1,1
    • Insert the metal screwdriver as pictured: oriented vertically, underneath the yellow plastic piece in the switch assembly, between the metal contact of the switch and the gray plastic slider flange.
    • Pry upward to remove the yellow plastic piece; the metal contact piece may pop out with the plastic piece.
    • Once the metal and plastic are unseated from one side, pull out the metal contact and yellow plastic piece with pliers or fingers. Remove these pieces.
  7. Panasonic Super Lite Flashlight Teardown: 步骤 7 中的图像 1,1
    • Use pliers to pinch the gray flanges of the switch slider and apply pressure to push the switch out of the flashlight body.
Colin Mitchell
于04/11/11注册
257 声望
撰写一个指南
团队
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G26
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,821
