简介
If your Panasonic SDR-H85 camcorder isn’t able to store footage, is making strange clicking noises, and has software that is constantly crashing it means that you have a faulty hard drive. Use this guide to replace the hard drive for the Panasonic SDR-H85 camcorder. The hard drive is responsible for the storage of software and is the main computing component of the camcorder. Failure within the hard drive will render the camcorder useless. Before using this guide, feel free to refer to the troubleshooting page for the Panasonic SDR-H85 to see which replacement guide best matches your device’s symptoms. Make sure you remove the battery and disconnect the power before you start.
你所需要的
Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
2等其他人完成本指南。
