你所需要的
Remove right side shell. There are two screws that are right behind the strap that also need to be removed.
Remove the three screws highlighted in the pictures shown.
To avoid damaging the device, slowly pick up the hard drive to reveal an orange ribbon cable attached to the motherboard pull back on the dark brown tab and carefully pull out the ribbon cable . Then you may proceed with removing the hard drive.
Remove the screws circled.
Pull front section away from the rest of the camera to remove it.
Remove screw circled.
Use a spudger to pull up the black shell and pull it away from the rest of the camera.
