跳转到主内容
Panasonic SDR-H40P Hard drive Replacement
你所需要的
  1. Panasonic SDR-H40P Hard drive Replacement, Hard drive: 步骤 1 中的图像 1,3 Panasonic SDR-H40P Hard drive Replacement, Hard drive: 步骤 1 中的图像 2,3 Panasonic SDR-H40P Hard drive Replacement, Hard drive: 步骤 1 中的图像 3,3
    • Remove battery first.
    • Remove right side shell. There are two screws that are right behind the strap that also need to be removed.
    • Prepare to keep track of many tiny screws.
    • Keep track of where all your screws unscrew from. Some of these screws have a slightly different size compared to others and will get stuck inside the holes when putting it back together.
  2. Panasonic SDR-H40P Hard drive Replacement: 步骤 2 中的图像 1,3 Panasonic SDR-H40P Hard drive Replacement: 步骤 2 中的图像 2,3 Panasonic SDR-H40P Hard drive Replacement: 步骤 2 中的图像 3,3
    • Remove indicated screws to release back panel.
  3. Panasonic SDR-H40P Hard drive Replacement: 步骤 3 中的图像 1,2 Panasonic SDR-H40P Hard drive Replacement: 步骤 3 中的图像 2,2
    • This is a continuation of Step 2.
    • Remove the last screw.
    • To remove the panel you simply pull it back.
    • There is a ribbon cable attached the the motherboard. Be sure to pull the panel back slowly, and detach the ribbon cable.
  4. Panasonic SDR-H40P Hard drive Replacement: 步骤 4 中的图像 1,3 Panasonic SDR-H40P Hard drive Replacement: 步骤 4 中的图像 2,3 Panasonic SDR-H40P Hard drive Replacement: 步骤 4 中的图像 3,3
    • Remove the three screws highlighted in the pictures shown.
    • Do not use force on the hard drive.
    • To avoid damaging the device, slowly pick up the hard drive to reveal an orange ribbon cable attached to the motherboard pull back on the dark brown tab and carefully pull out the ribbon cable . Then you may proceed with removing the hard drive.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 435
