简介
If your Panasonic SDR H-100 zoom lever is sticking, working inconsistently, or not working at all, then use this guide to replace the malfunctioning part.
The zoom function on the Panasonic SDR H-100 allows the user to move their point of view closer to or further from the subject.
Before beginning, make sure to completely power off your device and disconnect it from any external power sources.
你所需要的
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
