你所需要的
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
Remove the black 4 mm screw located on the back of the camcorder under the SD card slot.
即将完成!
结论
