跳转到主内容
Panasonic SDR H-100 HDD Replacement
你所需要的
  1. Panasonic SDR H-100 HDD Replacement, Remove Bottom Screws: 步骤 1 中的图像 1,2 Panasonic SDR H-100 HDD Replacement, Remove Bottom Screws: 步骤 1 中的图像 2,2
    • Remove the four 4-mm screws on the bottom of the camcorder.
    • The screws are two different colors: three blacks and one silver.
  2. Panasonic SDR H-100 HDD Replacement, Remove Side Screws: 步骤 2 中的图像 1,1
    • Remove the three 6-mm screws on the hand-strap side of the camera.
  3. Panasonic SDR H-100 HDD Replacement, Remove DC Input Terminal Screws: 步骤 3 中的图像 1,1
    • Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
  4. Panasonic SDR H-100 HDD Replacement, Remove LCD Monitor Screws: 步骤 4 中的图像 1,2 Panasonic SDR H-100 HDD Replacement, Remove LCD Monitor Screws: 步骤 4 中的图像 2,2
    • Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
    • One screw is located by the hinge of the LCD screen. The second is close to the upper-right corner of the camcorder body.
    • Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
    • Pressure should be evenly distributed across entire device.
    • Detach gently so the ribbon cable is not damaged!
  5. Panasonic SDR H-100 HDD Replacement, Detach Ribbon Cable from Body: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
    • This linkage point connects the HDD directly to the motherboard.
  6. Panasonic SDR H-100 HDD Replacement, HDD: 步骤 7 中的图像 1,1
    • Remove the two 4 mm silver screws located on the HDD casing.
  7. Panasonic SDR H-100 HDD Replacement: 步骤 8 中的图像 1,1
    • Gently pull the black plastic hard drive case away from the body of the camera. This will expose the hard drive (HDD).
  8. Panasonic SDR H-100 HDD Replacement: 步骤 9 中的图像 1,1
    • Pry off the HDD gently from the casing with a plastic opening tool.
    • Make sure to run the tool underneath the HDD as you pry it off.
  9. Panasonic SDR H-100 HDD Replacement: 步骤 10 中的图像 1,1
    • The HDD has been removed and ready to be replaced.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,572
