跳转到主内容
Panasonic SC-PM31 Fuse Replacement
你所需要的
  1. Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: 步骤 1 中的图像 1,3 Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: 步骤 1 中的图像 2,3 Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: 步骤 1 中的图像 3,3
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
  2. Panasonic SC-PM31 Fuse Replacement, Removing the panels: 步骤 2 中的图像 1,2 Panasonic SC-PM31 Fuse Replacement, Removing the panels: 步骤 2 中的图像 2,2
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
  3. Panasonic SC-PM31 Fuse Replacement, Removing the white ribbon wire: 步骤 3 中的图像 1,1
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
  4. Panasonic SC-PM31 Fuse Replacement, Removing the top panel: 步骤 4 中的图像 1,2 Panasonic SC-PM31 Fuse Replacement, Removing the top panel: 步骤 4 中的图像 2,2
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
  5. Panasonic SC-PM31 Fuse Replacement, Removing the back panel screws: 步骤 5 中的图像 1,1
    • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
  6. Panasonic SC-PM31 Fuse Replacement, Removing the back panel: 步骤 6 中的图像 1,3 Panasonic SC-PM31 Fuse Replacement, Removing the back panel: 步骤 6 中的图像 2,3 Panasonic SC-PM31 Fuse Replacement, Removing the back panel: 步骤 6 中的图像 3,3
    • With a gentle tug, unplug the red and black cable from the tan circuit board.
    • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
    • Slide the back panel toward you and off of the unit.
  7. Panasonic SC-PM31 Fuse Replacement, Removing the fuse: 步骤 7 中的图像 1,2 Panasonic SC-PM31 Fuse Replacement, Removing the fuse: 步骤 7 中的图像 2,2
    • Looking over the top of the tan and green circuit board, locate the fuse.
    • Gently pull the fuse out of the metal claps.
结论
另外一个人完成了本指南。
Jessica Chao
于09/29/14注册
626 声望
创作了5篇指南
团队
Cal Poly, Team 13-7, Forte Fall 2014 Cal Poly, Team 13-7, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G7
5 名成员
创作了7篇指南
2条评论
What symptoms did fuse failure exhibit?
Any information on stereo decoding and LCD display faults?
Chris Phillips - 回复
Will this fix the dead LCD display? Thanks
samkok37 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 23
总计 4,142
