本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
Now rotate the device 180 degrees and remove the second screw.
Remove the screw that is on the right side of the panel facing you.
All screws will need to be removed with a phillips head screwdriver.
即将完成!
结论
