跳转到主内容
加入维修社区 - 创建账户
Panasonic SA-HT810V DVD Drive Replacement
你所需要的
    1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 1,3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 2,3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 3,3
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • Remove all screws with a phillips head screwdriver.
      询问修复机器人
      添加评论
    2. Panasonic SA-HT810V DVD Drive Replacement: 步骤 2 中的图像 1,2 Panasonic SA-HT810V DVD Drive Replacement: 步骤 2 中的图像 2,2
      • Rotate the device so that the back faces you.
      • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
      询问修复机器人
      添加评论
    3. Panasonic SA-HT810V DVD Drive Replacement: 步骤 3 中的图像 1,1
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      询问修复机器人
      添加评论
    4. Panasonic SA-HT810V DVD Drive Replacement: 步骤 4 中的图像 1,3 Panasonic SA-HT810V DVD Drive Replacement: 步骤 4 中的图像 2,3 Panasonic SA-HT810V DVD Drive Replacement: 步骤 4 中的图像 3,3
      • Pull up the two tabs on top
      • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device with a flat head screwdriver.
      询问修复机器人
      添加评论
    5. Panasonic SA-HT810V DVD Drive Replacement: 步骤 5 中的图像 1,1
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      询问修复机器人
      添加评论
    6. Panasonic SA-HT810V DVD Drive Replacement: 步骤 6 中的图像 1,2 Panasonic SA-HT810V DVD Drive Replacement: 步骤 6 中的图像 2,2
      • Remove the four screws around the DVD drive with a phillips head screwdriver.
      询问修复机器人
      添加评论
    7. Panasonic SA-HT810V DVD Drive Replacement: 步骤 7 中的图像 1,1
      • The DVD player is attached to the power supply.
      • Remove the wire attaching it by firmly pulling on the wire until it releases.
      询问修复机器人
      添加评论
    8. Panasonic SA-HT810V DVD Drive Replacement: 步骤 8 中的图像 1,1
      • Flip the DVD drive so that the bottom is facing you.
      • Pull on the blue ribbon cable until it releases.
      • To place the new DVD drive in just follow these steps in reverse.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G5
4 名成员
创作了84篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 61
总计 2,090
