跳转到主内容
Panasonic RQ-2102 Holding Handle Replacement
你所需要的
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 步骤 1 中的图像 1,3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 步骤 1 中的图像 2,3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: 步骤 1 中的图像 3,3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: 步骤 2 中的图像 1,2 Panasonic RQ-2102 Holding Handle Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 588
