跳转到主内容
Panasonic RQ-2102 Cassette Holder Spring Replacement
你所需要的
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 步骤 1 中的图像 1,3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 步骤 1 中的图像 2,3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: 步骤 1 中的图像 3,3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: 步骤 2 中的图像 1,3 Panasonic RQ-2102 Cassette Holder Spring Replacement: 步骤 2 中的图像 2,3 Panasonic RQ-2102 Cassette Holder Spring Replacement: 步骤 2 中的图像 3,3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: 步骤 3 中的图像 1,2 Panasonic RQ-2102 Cassette Holder Spring Replacement: 步骤 3 中的图像 2,2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 1,024
