当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Rotate the camcorder so that the eye piece is facing you.
Remove the four black 4.5mm screws, sitting behind the battery.
Remove the 5th screw to the right of the battery dock.
Remove the battery by gently pulling away from the camcorder.
Be careful and place screws together so you don't lose any.
Rotate the camcorder so that the tape compartment is facing you.
Remove the single 4.5mm black screw above the hook for the hand strap.
Undoing the strap on one end may help.
Rotate the camcorder so that the lens is facing you.
Remove the single 4.5mm black screw from the front panel.
Rotate the camcorder so that the bottom is facing towards you.
Remove the single remaining 4.5mm black screw from the bottom.
Remove the four silver 4.5mm screws from the body.
Open the LCD screen on the side of the camcorder.
Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
Carefully remove the front cover from the body of the camcorder.
This should come apart with relative ease, however a plastic opening tool may help remove the panel.
There is a ribbon cable attached to the front panel and the camcorder body, DO NOT pull that off when you remove this panel.
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
Using two tools may be useful, if difficult.
Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
Remove the panel from the camcorder.
Before removing the LCD panel from the camcorder, disconnect the ribbon cables joining the LCD panel to the logic board.
There may be multiple ribbon cables attached to the same point on the logic board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
