跳转到主内容
Panasonic Lumx DMC-ZS19 Lens Replacement
你所需要的
  1. Panasonic Lumx DMC-ZS19 Lens Replacement, LCD Screen: 步骤 1 中的图像 1,3 Panasonic Lumx DMC-ZS19 Lens Replacement, LCD Screen: 步骤 1 中的图像 2,3 Panasonic Lumx DMC-ZS19 Lens Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 2 中的图像 1,1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 3 中的图像 1,1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 4 中的图像 1,1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
  5. Panasonic Lumx DMC-ZS19 Lens Replacement, Lens: 步骤 5 中的图像 1,2 Panasonic Lumx DMC-ZS19 Lens Replacement, Lens: 步骤 5 中的图像 2,2
    • After the screen has been removed, the main motherboard is directly underneath it. There is a bronze, metal separation piece that separates the main motherboard from the one connected to the lens. This metal piece is held in with 3 screws. Remove these 3 screws and the metal piece will be free.
  6. Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 6 中的图像 1,1
    • Once the bronze metal plate is removed, the main motherboard will be exposed. There is a plastic riser (it looks like a lowercase "b" on the right side of the camera) that separates the metal plate from the motherboard. Remove this plastic riser.
  7. Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 7 中的图像 1,3 Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 7 中的图像 2,3 Panasonic Lumx DMC-ZS19 Lens Replacement: 步骤 7 中的图像 3,3
    • Once the plastic riser is removed, it is time to remove the lens. To do this, simply follow the data strips (2) that connect the lens to the main motherboard and unclip them by turning the black bar into a position that is perpendicular to the motherboard. Once these clips are open, the data strips and the lens should simply slide out.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015 的会员
USFT-MEIER-F15S14G1
4 名成员
创作了10篇指南
3条评论
I want to replace the lens but the description is for the motherboard??
Michael F Delaney - 回复
Looks like an honest mistake; I updated the introduction to remove the reference to the motherboard. Sorry for the confusion!
Jeff Suovanen -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 1,731
