跳转到主内容
Panasonic Lumx DMC-ZS19 LCD Screen Replacement
你所需要的
  1. Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Panasonic Lumx DMC-ZS19 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
结论
团队
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015 的会员
USFT-MEIER-F15S14G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 320
