跳转到主内容
Panasonic Lumix ZS50 Lens Assembly Replacement
你所需要的
  1. Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic Lumix ZS50 Lens Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 2 中的图像 2,2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 3 中的图像 1,1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 4 中的图像 1,1
    • The battery should now be released; you may now remove the battery from the camera body.
  5. Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 步骤 5 中的图像 1,3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 步骤 5 中的图像 2,3 Panasonic Lumix ZS50 Lens Assembly Replacement, LCD Screen: 步骤 5 中的图像 3,3
    • Orient the camera so the bottom is facing up and the battery door is on the right side.
    • Remove four black screws from the bottom of the camera.
    • Remove two black screws from the right side of the camera.
    • Remove one black screw from the left side of the camera.
  6. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 6 中的图像 1,2 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 6 中的图像 2,2
    • Remove the casing from the camera by hand or using a plastic opening tool.
  7. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to lift up and tug off the green button board.
    • Be careful to not damage the attached ribbon cable.
  8. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 8 中的图像 1,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 8 中的图像 2,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the screen using the plastic opening tool, prying from the top.
    • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
  9. Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 步骤 9 中的图像 1,3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 步骤 9 中的图像 2,3 Panasonic Lumix ZS50 Lens Assembly Replacement, Lens Assembly: 步骤 9 中的图像 3,3
    • Remove the three screws from the center of the copper plate.
    • Remove the four screws from the outer edges of the copper plate.
    • Use a plastic or metal spudger to pry the copper plate out of place.
  10. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove the casing from the circuitboard by hand.
    • Remove the HDMI port casing by hand.
  11. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 11 中的图像 3,3
    • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
    • Disconnect the circuitboard by hand.
    • There will be one orange ribbon cable attached to the top that can now be removed.
  12. Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 12 中的图像 1,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 12 中的图像 2,3 Panasonic Lumix ZS50 Lens Assembly Replacement: 步骤 12 中的图像 3,3
    • Remove the seven screws surrounding the lens assembly.
    • Move all ribbon cables out of your way while unscrewing.
    • Remove the three springs surrounding the lens.
    • Apply pressure on the front of the lens to push the lens out.
结论
Bridget Lathrop
于02/01/17注册
149 声望
创作了2篇指南
团队
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 1,032
