跳转到主内容
Panasonic Lumix ZS50 Battery Replacement
你所需要的
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic Lumix ZS50 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix ZS50 Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: 步骤 3 中的图像 1,1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: 步骤 4 中的图像 1,1
    • The battery should now be released; you may now remove the battery from the camera body.
结论
另外一个人完成了本指南。
Cameron Voos
于02/01/17注册
32 声望
撰写一个指南
团队
Baylor, Team 8-5, Whitney Spring 2017 Baylor, Team 8-5, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G5
3 名成员
创作了4篇指南
一条评论
Repair guide is very clear and well-done
BayleeVersteeg - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 510
