跳转到主内容
Panasonic Lumix DMC-ZS6 SD Card Reader Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement, SD Card Reader: 步骤 1 中的图像 1,1
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 2 中的图像 3,3
    • Unscrew the bottom two 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 4 中的图像 2,2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 5 中的图像 1,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 5 中的图像 2,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 5 中的图像 3,3
    • Unscrew the bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 6 中的图像 1,1
    • Separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 7 中的图像 2,2
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 8 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 8 中的图像 2,2
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab.
    • Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 9 中的图像 1,1
    • Insert the tip of the spudger into the center hole of the tripod mount.
    • Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 10 中的图像 2,2
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard.
    • Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 11 中的图像 3,3
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three 1.0 mm silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 12 中的图像 1,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 12 中的图像 2,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 12 中的图像 3,3
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
  13. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 13 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 13 中的图像 2,2
    • Use the spudger to disengage the two tabs.
    • Carefully lift the flash assembly out of place.
  14. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 14 中的图像 1,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 14 中的图像 2,3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 14 中的图像 3,3
    • Use the tip of the spudger to flip up the tab to unseat the ribbon cable.
    • Unscrew the two silver 1.0 mm screws with a Phillips #000.
    • Use the tip of the spudger to disengage the two plastic tabs, and carefully lift the motherboard out of place.
  15. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 15 中的图像 1,2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 15 中的图像 2,2
    • Unscrew the one silver 1.0 mm screw with a Phillips #000 screwdriver.
    • Use to tip of the spudger to disengage the plastic tab, then carefully lift the plastic shield out of place.
  16. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: 步骤 16 中的图像 1,1
    • Carefully lift the SD card reader assembly out of place.
结论
Derrick Thompson
于01/30/18注册
1,035 声望
创作了5篇指南
团队
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,305
