跳转到主内容
Panasonic Lumix DMC-ZS6 Lens Assembly Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement, Lens Assembly: 步骤 1 中的图像 1,1
    • Remove the battery and the SD Card.
  2. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 2 中的图像 3,3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the tip of the 2.0 mm flathead screwdriver to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 5 中的图像 1,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 5 中的图像 2,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 5 中的图像 3,3
  6. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 6 中的图像 1,1
    • Carefully separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 7 中的图像 1,2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 7 中的图像 2,2
    • Use the tip of the 1.5 mm flathead screwdriver to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 8 中的图像 1,2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 8 中的图像 2,2
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the 2.0 mm flathead to disengage the metal tab, then carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Insert the tip of the 2.0 mm flathead into the center hole of the tripod mount, and apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 10 中的图像 2,2
    • Use the 2.0 mm flathead to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the 2.0 mm flathead screwdriver into the hole on the daughterboard, then apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 11 中的图像 1,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 11 中的图像 2,3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: 步骤 11 中的图像 3,3
    • Use the 2.0 mm flathead to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Carefully lift the lens assembly out of the camera.
结论
Derrick Thompson
于01/30/18注册
1,035 声望
创作了5篇指南
团队
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 591
