跳转到主内容
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: 步骤 1 中的图像 1,1
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 2 中的图像 1,3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 2 中的图像 2,3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 2 中的图像 3,3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 3 中的图像 1,1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: 步骤 5 中的图像 1,1
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
结论
Derrick Thompson
于01/30/18注册
1,035 声望
创作了5篇指南
团队
Baylor, Team S2-G5, Johnson Spring 2018 Baylor, Team S2-G5, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 182
