跳转到主内容
Panasonic Lumix DMC-ZS40 Camera Sensor Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 步骤 1 中的图像 1,2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 步骤 1 中的图像 2,2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 2 中的图像 1,1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 3 中的图像 2,2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 步骤 4 中的图像 1,3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 步骤 4 中的图像 2,3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 步骤 4 中的图像 3,3
    • Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
  5. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 5 中的图像 1,2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 5 中的图像 2,2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 6 中的图像 1,1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 7 中的图像 1,3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 7 中的图像 2,3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 7 中的图像 3,3
    • Place the LCD screen to the side while you remove the plate cover. The LCD has already been removed in this picture. It is not necessary to remove the LCD screen or the control dial for this guide.
    • Remove these four 4mm screws and the 3mm screw on the top of the plate cover and on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  8. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the ribbon cable connecting the sensor to the motherboard. Use tweezers or a screw driver to lift up on the retaining flap of the ZIF connector to remove the cable.
  9. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 9 中的图像 1,1
    • Using the T3 Phillips Screwdriver, unscrew the three Torx T3 2.5mm screws holding the sensor down.
  10. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 10 中的图像 1,2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 步骤 10 中的图像 2,2
    • Gently lift the sensor off of the springs.
结论
另外一个人完成了本指南。
Dean Favetta
于02/14/17注册
340 声望
创作了3篇指南
团队
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G3
3 名成员
创作了10篇指南
一条评论
After the CCD is replaced, how do you adjust the 3 torx screws, so the ccd is in alignment? After the replacement the right side of my pictures are out of focus.
resufix888 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 988
