跳转到主内容
Panasonic Lumix DMC-ZS3 Battery Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: 步骤 2 中的图像 1,1
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: 步骤 3 中的图像 1,1
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: 步骤 4 中的图像 1,2 Panasonic Lumix DMC-ZS3 Battery Replacement: 步骤 4 中的图像 2,2
    • Pull the battery out of the camera.
    • The battery should slide out easily.
结论
团队
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G60
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 23
总计 1,280
