跳转到主内容
Panasonic Lumix DMC-ZS3 Back Cover Replacement
你所需要的
  1. Panasonic Lumix DMC-ZS3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Panasonic Lumix DMC-ZS3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Panasonic Lumix DMC-ZS3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Back Cover Replacement: 步骤 2 中的图像 1,2 Panasonic Lumix DMC-ZS3 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Back Cover Replacement: 步骤 3 中的图像 1,2 Panasonic Lumix DMC-ZS3 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Back Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the two LCD board ribbon cables out of their sockets.
结论
团队
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G60
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 795
